The car at college thing is bad for the car. Tires shake, gas gets water in (if you don't keep it FULL while parked), car rusts, gas tank rusts, people hit the car ... not good all around. I do drive pretty slow and conservative for a 19 year old.
I've been pondering the idea of getting a
scangauge for about 2 years now. Still haven't made the decision haha.
The closest I was going to do to aeromodding was blocking off the upper and lower grille in winter. I have extra cooling on the transmission. In the winter this causes it to not heat up enough and the torque converter clutch doesn't lock because the transmission oil isn't the right temperature
