Old 07-08-2008, 11:50 PM   #6 (permalink)
Cd
no
Cd's Avatar
- - '93 Civic DX hatchback
Whoever thought of using water as a testing method is pretty clever !
The picture with the headlights up looks just like what you would see in a windtunnel.
I've always wanted to see what the underside of a T/A looks like. Thanks !
Can we see some more shots of how the air damn ... dam is set up ? It appears as if there is not a real 'scoop' there, but rather a flat panel that the air smacks into and gets pushed into the radiator. Can we see where the radiator is in reference to the air dam ?
Also, thanks for setting the white balance on your camera so that we could see the details in the dark areas. ( Or did you edit them in PhotoShop ? ).
