Old 07-09-2008, 11:34 AM   #10 (permalink)
twentysixtwo
Spoilers bad!
BTW, noticed you have a spoiler. Most spoilers are cosmetic. Those that aren't cosmetic typically help reduce aero lift (Audi TT is prime example where lift at speed makes it unsafe, they actually had a recall to install spoilers)
Either way, this means more drag. Based on where it is on the Camaro, I'd suggest you could improve your aero by removing it, though there will likely be bolt holes left when you do.......
