Don't go with the smallest amp hour battery. If the larger ones are too much to go all in the rear, you'd be better off to split the pack and put some up front as well. Don't forget that the larger capacity pack will last longer if you're not drawing the batteries down as deeply as the smaller pack each time you use the car.
