Old 07-10-2008, 12:39 PM   #5 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Originally Posted by othergames View Post
I thought of that too, but the cans aren't PRECISELY 5 gallons. This is probably the best way, though. At the pump I have to make sure I record what goes into my car, then fill up 3 5-gal cans with precisely 5 gallons each, then 30 - 15 - my fill up = the leftover in the 4th can.
I would put increment marks on the can with permanent marker, up to 5 gallons. Do this by starting with an empty can on a level surface and putting marks on as you reach every increment with the gas pump. It will make it easier to track how much you put into the car, just check the level when you set the can back down. Maybe even tie a scratch pad to the handle of the can.
Winter daily driver, parked most days right now
Summer daily driver
