Old 06-13-2014, 11:37 PM   #14 (permalink)
oil pan 4
I dont try to pull a high vacuum. I figure tires are made to hold pressure in, not the other way around.
I put the air powered vacuum pump on it and let it pull air out till the side walls suck in a little bit.
Then it takes a lot of CO2 to bring them up to 30psig.
So far they have been holding CO2 like a champ.
Next step will be to bleed the CO2 down to 15psig, then bring it up to 40psig with R-404a.
Next time I fill with CO2 I will weigh the bottle before and after.
