Old 07-11-2008, 09:23 AM   #91 (permalink)
n8thegr8
N8sPony - '98 Mustang
the arduino software has the serial monitor, so after you compile and load it, you can click the serial monitor button on the top right and watch what's going through the serial tx/rx. I've been using serial.println() to send my variables to the console to make sure I've got the correct values. you just set the baud rate to whatever you set it to when you did Serial.begin() in your code.
