The pump you pictured is most likely AIR powered. (Venturi action)
The TDI has a cam driven Vacuum pump.
The Supra has an Electric Pump! It is however very small You could use 2~3 Should be able to buy them cheap; you can remove them and only loose your cruise + brakes under boost. (Who ever stops when they are boosting?)
6 speed ALH TDI
