Old 07-11-2008, 09:07 PM   #1 (permalink)
Impulse
Lurking Around
Impulse's Avatar
96 Civic - '96 Civic CX
90 day: 35.61 mpg (US)
03 Corolla - '03 Corolla S
90 day: 30.35 mpg (US)
09 Sierra - '09 Sierra SLE
90 day: 19.76 mpg (US)
96-00 Civic Upper Grill Block
Well I finally had time after work to work on the Civic, so I made a quick and easy upper grill block as seen here (Aftermarket Grill, costs about $20)
I found some chloroplast scraps we had laying around the shop, which is about 1/4 inch thick and is somewhat bendable to an extent
Next I used an exacto knife to cut the rough dimension of th insert out
Then I took a pencil and marked the inside mouth of the grill onto the chloroplast, and cut around the penil marks about 1/4 inch all the way around
Next I screwed the chloroplast from the back side into the grill, there are already screw mounting holes molded in the aftermarket grill that I got
Finshed result.
Fitted to the car. Take note that I had to take out the screws along the top of the grill that held on the chloroplast because the grill would not fit using the screws that I chose, so it is pressure fit in between the grill and the rad support, probably more solid than the screws.
Now to get some ecomiling in!!
