Wheel/Fender Skirts...
My fender skirts are 1/4" from the tire. I used two 1/4" rods, one at the top, one at the bottom. The bottom rod is basically U shaped and slides into metal wire clamps and held by two small pins. The top support rod is pretty much straight and slips through a bracket at the rear of the wheel well and is held in place by a single screw at the front.
Honda...the economical, renewable resource.
