Try This SirKeats
What I did was pipe everything over to the right side of the engine compartment and put my PCV catch can there. I used a 2 1/2" pvc pipe with rubber plumbing caps on the top and bottom. Put the inlet line down to the bottom of the pipe and the outlet near the top.
I used silica alumina and zeolites (both catalysts) inside the unit. The zeolites act as a molecular sieve and break down the hydrocarbons from long chain into short chain. That's what the professionals (oil refineries) use to achieve a 41% increase of petroleum cracked into the gasoline range from the same amount of crude oil.
You need to pipe out of the valve cover outlet to the can and down to the bottom of the pvc pipe as mentioned. Then out of the pipe near the top and then you will have to put a tee into the line to go to the air breather and into the regular PCV valve.
HTH,
MooNShiNeR
