Old 07-20-2014, 03:29 AM   #28 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by Enki View Post
Have you considered doubling up on the capacitors to reduce the voltage drop at start?
That was the same thought I had. Running caps in a series/parallel config.
If I were to make this a permanent solution, I would likely run 1500F capacitors instead of the 350s. The kit on Ebay is $209.
I am also considering reducing or eliminating the current limiting resistor so that the LiFePO4 can contribute more to starting the vehicle.
My third idea is to connect the battery to the capacitor with 2 parallel connections. 1 connection would have a current limiting resistor to reduce the rate of charge. The other connection would have a power diode that would allow the battery to supply cranking amps (at a 1v reduction), but not allow charging through that connection.
I am reading this thread with great interest, but don't think I am following your thought process here with the battery/capacitor connections thing.
