Old 07-14-2008, 11:44 AM   #1 (permalink)
Raysp30
SaturnSl1 - '00 SL1
90 day: 40.21 mpg (US)
MyPickup - '96 Ranger
CRX HF - '89 CRX HF
90 day: 51.59 mpg (US)
Permanent Grill Block
I went to look at my grill block last week and it was deteriorating quite a bit with all of the rain lately. It was made out of two layers of foam board and wrapped in tape around the 75% of the grill.
I decided to go all the way when I started thinking about a permanent solution.
I started with putting cardboard behind the grill and then inserted three 1 1//2" PVC pipe sections into the existing grill for venting. Then I sprayed the entire grill with gap seal. It's like insulating foam, except doesn't cause the same problems that other people have had on this board. Once the foam cured, I cut it to shape using a hacksaw blade. Filled in gaps with more foam, cured, cut again.
Once I had the shape I wanted I went for a test drive. Turns out 3 little openings were't quite enough for cooling the engine. I was getting temps around 210F on the highway and 220F+ with stop and go traffic. Went home, cut 4 more holes and went for another drive. 7 holes seems to be the right number for my Saturn. No overheating.
After all the foam was cured, I started putting Bondo over everything. I still have quite a bit of sanding to do before I paint it with factory spray paint. I'm hoping to get it so close that you can only tell from a few inches away where my paint job started.
Not done yet, but the pictures should give a pretty good idea of where I'm at.
As a side note: the test drive I did was after I installed the belly pan.
