Originally Posted by aerohead
Is there any truth to the rumor that the price of cardboard,aluminum foil,and duct-tape are expected to make a big leap?
Thanks for the chuckle! Right up there with copper and lead, I'm sure.
If you pull the front wheel off the bike,could you cheat it under the new lid?
Nah, I'll just stick it inside the hatchback where it belongs.
Originally Posted by brucey
Looking at how big this thing is getting. I'm starting to wonder if fiberglass was the right way to do it.
It was the right way to do it when I was aiming for complex curves. With the simple curves I ended up with (see up the thread for the great stuff foam problems), plastic or plexi would have worked. But I'd already started.
Originally Posted by atomicradish
How easily can this "permanent" Kammback be removed?
It'll be easily removable. I did however drill the hatch to attach mounting brackets last night, so those holes would need to be covered if I ever removed it. I was loath to drill. But... it's in an area that isn't rust prone (the vertical metal above the rear glass), which was my main concern.
Yes, the car is a bit of a time capsule with ridiculously low mileage. But it is just a car, and I'm not planning to sell it, or put it in car shows. So I got over it, plugged in the drill, and pulled the trigger.
Originally Posted by bbjsw10
Can't Wait to see the MPG numbers from this
They're already available. Approx 2% improvement @ 55 mph.
Partial Kammback prototype tested - preliminary results
