Old 07-14-2008, 10:16 PM   #125 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
Originally Posted by dremd View Post
Assuming you have polished headlights before (I'm thinking you have) just toss them.
If not then here it goes
1) sand with 1000 grit until everything looks the same
2) sand with 2000 grit until everything looks the same
3) Medium rubbing compound until everything looks the same
4) Fine rubbing compound untill everything looks the same
5) Plastic polish to a high gloss
It is actually a good bit of work; on a bad headlight it might take an hour each.
What do you use for plastic polish? Where can it be purchased?
More choices...
