Old 07-15-2008, 06:13 AM   #1 (permalink)
Nden
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
Turtle EG seat swap Del Sol n2 EG Civic
after some mucking around with 2 decent Del Sol front seats (highly prized among honda owners) i bought at ecology for $23 pr I got them in my 92 VX !
About a month ago I tried or did a half-ass job installing the passenger Del Slow seat. I swapped only the outside rail at 1rst cuz it was super 90+ degree hot weather and mentally worn out from being in the sun a few hours at ecology earlier. Plus @ 1rst glance, it didn't look like i could take off the inner (close to ebrake) rail or seat pan completely. DUH me.
Finally SUN nite during sunset (cooler) I gave it the huzzzah try after speaking to some1 else who'd done the Del seat swap into an EG. On 1 side, there are 2x12mm nuts, and a single 10mm bolt that holds a rail to a "L" shaped piece which connects that rail to the seat pan & upper back part along with 2 or 3x14mm bolts.
DOWNside to swapping the driver's EG seat w/Del completely= del slow seat pan seems to be sunk lower so I felt like my seat was a low rider inside the car and was barely reaching the bottom rung of my steering wheel LOL . I was busy doing errands in the AM so I rode to work (pm 2nd shift) and back like this. It was comfy back support n legs but seemed too low and like the previous owner was a fat-ass cuz the thigh support was sort of at a decline. IMHO. So I swapped out the del sol seat pan with the EG bottom part of the seat and its back to the height I'm used to, with the highly desired back section of the del slow seat connected. Yes It's a true honda-hybrid now. The passenger side I shall finish completely swapping the inner rail as well & leave it that way, so I can chill out/nap in the passenger seat! Its soooo comfy in the passenger side w/complete del slow seat, but too low for me as a driver.
what u don't know, CAN hurt you because if you don't know your rights, its like you don't have any at all. ID Theft Services & Resolution available... check out
http://www.prepaidlegal.com/hub/deantaber
