Old 07-15-2008, 07:22 AM   #20 (permalink)
crexcrex
crx laminated plastic skirts
a bit small but will try again re pix...............before you weld galvanized steel think again the fumes are toxic................sunroof you can use the existing sunroof metal...remove hardware clamp sunroof edges into place tack and mig, grind and fill etc
Good luck
