Old 08-24-2014, 10:59 PM   #66 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Finally got around to taking care of some things on the Prius. The pizza pans were rusting out on the backside, so I replaced them with new ones and Plasti-dipped both sides before bolting them together. I also decided to go with a snazzier color:
I also (finally) installed the inside mirror on the driver's side:
I didn't get the position quite right before I drilled the A-pillar trim and bolted it on, so I might pull it off again and adjust it.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
aerohead (08-25-2014), SwamiSalami (09-28-2015)
