Old 08-30-2014, 10:12 PM   #23 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I think the ideal way to go is with a pump and external heat exchanger. Trans/diff pumps exist, but they aren't cheap. There must be a cheaper alternative out there.
Pumps - Mocal Differential Cooler Pump
http://www.summitracing.com/search/p...l-cooler-pumps
Combine a pump with a plate heat exchanger.
Plate heat exchanger - Wikipedia, the free encyclopedia
You could also add a filter. And even use the pump to change the fluid!
What about using a fluid thinner than recommended and just adding a trans cooler to keep viscosity up on long trips and/or hot weather? Same result of ideal and consistent viscosity without the warmup wait?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Daox (01-17-2017)
