Well, what my question is, do you think a larger sized oil filter would be FE beneficial rather than a small sized oil filter? I am not thinking in terms of doing anything to heat the oil, just wondering about the FE advantage of a larger filter.
Some engines, such as my 4 cyl. GMC Sonoma, come with a very small oil filter. I just finished cutting the motor mount area as required to accommodate the longer filter. My initial reason was simply to provide more filter area for the collection of dirt, but then it occurred to me that a larger filter should also make it easier for the engine driven, power robbing, oil pump to push oil thru it.
