Old 07-15-2008, 10:57 PM   #13 (permalink)
gascort
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
Originally Posted by Tony Raine View Post
compare trying to run down the road holding a 4'x8' sheet of plywood straight up to doing the same with a 4'x8' window screen.
But... to be less serious, could someone please try this and post video?
I bet the window screen has at least 50% of the resistance of a plywood sheet at high speeds though. Seems like a lot of turbulence would be generated.
The grill blocks on our cars also push air up, over, and around a vehicle that has good aerodynamics. The semi - it doesn't matter where the air goes around - it's not good.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
