Old 11-25-2007, 09:59 PM   #113 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
05-26-2006, 01:06 Pm
DAX suggests welding the differential to create a "spool" and going 1-wheel drive with the big motor.
Thanks DaX.
So it is possible. Interesting. I can't picture how a "spool" would be set up, since I don't really know how a diff works in the first place, but I'm sure I can figure it out. (Until I pulled the pressure plate off the motor this morning, I never had a clear understanding of clutch operation either. I had it all backwards, thinking the clutch plate was attached to the pedal...)
And regarding loss of traction, does that apply if you don't have a LSD? If I put a wheel on ice and one on pavement, the car won't go anywhere - the ice wheel just spins. So, no change there.
One thing I was wondering about was if it would affect handling - ie. would the steering "pull" all the time? Just when accelerating? Would it behave oddly in tight turns? (In one direction, the motor would run faster than the opposite turn.)
