Old 10-02-2014, 04:19 PM   #9 (permalink)
Daox
Darin seems to think that I should be expecting 60+ mpg without any real mods with my commute. Going into fall, I'm not so sure. I think that might be a little work, but in summer that should be achievable. 60+ is where I'd like to be.
I'll most likely be fixing the rear sway bar. I like a tighter handling car. The fix shouldn't be a big deal anyways. FE wise, it won't be worth anything to remove a ~10lb bar.
The Following User Says Thank You to Daox For This Useful Post:
MobilOne (05-05-2015)
