I always figured the best spot for a kill switch would be on the center console right below the arm rest where those factory blank panels are (where the parking pole switch on European market civics are)
He was breaking the switch because of its movement on the shifter. I know it's not what you ment but a foot operated switch sounds intriguing too. Put a bicycle shoe on the gas pedal so you can lift up the pedal to engage a switch that kills the injectors
Also had a thought the other day, I wonder if you could use the window switch panel from a civic sedan and wire the two switches for the back window to function as an auxiliary switch. You have crank windows so technically you just need to cut the hole for the window crank on a power window panel for a coupe and you would have 4 switches on the door you could use for anything you wanted
On reducing drag the rear trunk area of the civic is deformed and massive compared to that tiny spare. Underbelly pan under the trunk combined with your aero spoiler would have a much greater effect on mileage.
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
