Old 07-17-2008, 11:12 PM   #8 (permalink)
larryrose11
Mad Scientist
Silver Civic - '97 Civic 2 door DX coupe
90 day: 35.57 mpg (US)
Wagon - '01 Foccs ZTX
90 day: 35.46 mpg (US)
Here is a pic of our exterior remodel, or at least the insulation layers. On the front is the 2.5 lb per cubic foot, 3 inch thick polyurethane spray foam in the stud cavity, and on the side you can see the 1 inch foam decking that is covering the spray foam. Overkill perhaps, but there are health issues in the house with mildew, which drove this solution. The foam contractors also installed a plug of foam above the wall header at the eves, and filed the joust cavity in the basement where the house meets the foundation. There is a fresh or make up air inlet in the basement with a sealing air valve that opens on air pressure. The furnace gas solenoid also drives a relay, turning on a small (80 CFM) exhaust fan insuring fresh air in the house in the winter. My heating bill would be lower If I had a high efficiency furnace, but I don't. The furnace is original 1963 equipment and in good shape. High efficiency furnace without good insulation just efficiently wastes heat.
File Type: jpg The latest.. a pretty new porch_small.JPG (74.8 KB, 39 views)
