Old 10-22-2014, 08:25 PM   #18 (permalink)
blownoiler
performance with economy
I believe, based on what I've read here, that I'll be installing a larger filter in my Insight when it comes time to change. Since it only holds ~2qts of oil, I can probably safely extend the oil change interval a bit too, given the larger amount of oil.
You might find this blurb on oil filter construction/filtering interesting!
Everything About Filters-All Black Diesel
http://www.austincc.edu/wkibbe/oilfilterstudy.htm
The Following User Says Thank You to blownoiler For This Useful Post:
Ecky (10-22-2014)
