Old 07-18-2008, 01:42 AM   #9 (permalink)
Concrete
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
coolorheat review & proto type ideas
$119 is high for an experiment
but if it saved me 2 mph on the truck that would pay back in one summer
has any one see this in a store - I would like to see how fast it cools
Wait... never mind
View All Reviews
- so much for a Peltier solution - I hate that - reality stinks sometimes
Back to the task at hand
Dremd
you could use screen or copper braid - quieter than foil
the problem is metal could abrade your seat foam, leather and tubing
The seat foam should insulate the tubes well, so you should just be cooling your butt. Maybe your first try could be just the slits & tubes.
especially if you are using ice water (Brrr)
it might not even need glue (at least short term), then you would be free to rework or redesign without permanently destroying anything, for now.
Concrete
Start where you are - Use what you have - Do what you can.
