I was thinking about that exact issue...aerodynamic turbulence caused by sidemarker lights. I like your solution, easy and inexpensive. The solution I was thinking of would be to eliminate the light cover that bulges out and instead have a flat piece of that transparent plastic attached to the outside of the car body, and the bulk of the light housing would be on the inside of the body.
