New gears could be as easy as just swapping in a new rear end. IIRC 00 Mustangs still used a solid rear axle so it shouldn't be too hard. Will net you gains highway cruising.
Lowering rotational mass always helps.
The aftermarket on Mustangs is huge, there should be some kind of reprogrammer you could get for your ECU To change the shift points.
