Old 07-20-2008, 07:03 PM   #445 (permalink)
cmags
cmags's Avatar
Scoob - '05 Impreza Outback Sport SE
90 day: 25.28 mpg (US)
^^ This project won't work via the OBD-II connector. OBD requires a communications protocol - we are pulling raw pulses from the VSS sensor and injectors for this project. You would have to tap into the appropriate lines on both vehicles and put a quick connect on the taps to switch between the two cars (don't forget power too).
There is an OBDuino in progress in another thread in this forum, but they're still in very preliminary stages and don't have the OBD communication working quite yet. This project is quite a bit further along in the process.
