Old 07-20-2008, 09:00 PM   #134 (permalink)
Johnny Mullet
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Originally Posted by Will View Post
Question for the mullet: How did you go about dealing with your DRLs?
I simply removed the center console.
Slide both seats forward and remove the 2 screws on the sides.
Raise the parking brake lever and get console out of way.
Looked for the wire at the back of the lever.
Loosened one mount bolt and ran wire under it to ground it.
WARNING.........
Doing this action to disable the daytime running lights has the same effect as pulling your parking brake lever up one click. This disables the DRL's, but it also illuminates the "BRAKE" light on the dashboard. You will have no warning if your brake fluid gets low, but most of us "Ecomodders" are always aware of our maintenance and check fluid levels.
Do not attempt to disable your DRL's this way unless you feel confident your car is visible and aware of the brake light issue.
