Old 07-20-2008, 10:13 PM   #5 (permalink)
Arminius
Future EV Owner
Wannabe - '05 Civic LX
90 day: 40.53 mpg (US)
Originally Posted by wyatt View Post
You may be able to buy (or make) a one way valve so air goes out, but not back in. You should be able to make it work without a problem. Like you say, the results should be minuscule, but I like your thinking.
Yeah, I thought about the valve thing, also using a separate fan. I'm not taking it too seriously yet, but if I had a car that i didn't mind cutting up I might make a bigger vent using air from the front side of the firewall and exiting out behind the license plate through a large diameter hose (front to rear). Better yet, I could draw air from beneath the rear of the car.
