Old 07-21-2008, 12:48 PM   #8 (permalink)
sohl
Ecomodding Dabbler
sohl's Avatar
LilRed - '03 Protege LX
90 day: 29.09 mpg (US)
OurOdyssey - '01 Odyssey EX
90 day: 16.12 mpg (US)
The film has held up to around 25 miles up through now, including a few miles at freeway speed. I notice a few very small wrinkles today, so it might be getting a bit loose at a spot or two. I'll try a bit more hot air to smooth it out.
Xringer: I actually had two layers when I first put it on, but the layers don't adhere to each other evenly, so you get a weird blotchy look. I'm thinking that it could be done with an even tougher film, like the mylar (?) used for model airplane construction.
MazdaMatt: If you want to try it, look up the grille removal discussion in some of the forums for Mazda-dedicated sites. I could dig up a URL if you can't find anything. The glossy/chrome strip along the top edge of the upper grille can be removed to help you wrap the film, but I think it's much better to do it after taking the upper grille off the car so you don't damage either part.
