If the torx bolts are not in too tight, you might be able to find a flat-blade screwdriver tip that will fit and loosen them. At least, that's how I got my Odyssey cross-bars off our van. On the other hand, you could mess up the tip of the screwdriver if you try it, so if you don't mind collecting tools, get the proper tip.
