Old 01-05-2015, 06:36 PM   #24 (permalink)
Ecky
90 day: 40.51 mpg (US)
Got mine set up!
I had previously cut a hole for the button but it interfered with the turn signal, so I had to cut another slightly lower. I need to get a big washer to cover the hole, but perforated board was all I had.
I attached the relay to a bolt-hole that was already in the rail, using one of the stock coated bolts used all over the car. I sandwiched the grounds between the relay and the rail, and ran the wire to my switch through the same grommet as the +12v for my amp.
