Old 07-22-2008, 02:33 AM   #43 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Me -
Originally Posted by cfg83 View Post
Question: How much solar panel square footage is needed to generate 12 volts DC at 1.5 Amps?!?!?!?!
CarloSW2
All About Solar Power - The Future is Solar
These two (amps and volts) can be combined together to say how much energy or power is involved. This is measured in watts. They combine using the equation:
Watts = Amps x Volts.
As all are giving producing a nominal 12 volts - using the equation above and assuming a bright (not necessarily sunny) day:
the 10 watt panel gives out just under 1 amp,
the 20 watt, gives out just over 1.5 amps
the 30 watt gives out exactly 2.5 amps.
Here is a 20 watt Solar Panel for $180, :
20 Watt Framed Solar Panel
Our new high quality and economically priced 20 watt framed solar panel is perfect for charging batteries or other small solar applications. Includes brackets for flat mounting.
Specs:
Rated power: 20 watts
Nominal voltage: 12 Volt
Peak voltage (Vmp):17.5 Volt
Peak current (Imp): 1.2 Amp
Dimensions: 360 x 530 x 17 mm, 14 x 20 x 0.7 inch
Weight: 2.5 Kg, 6 Lb.
The price is high, but at least the size is mangeable.
CarloSW2
American Solar Energy Society
