Old 07-22-2008, 02:16 PM   #5 (permalink)
dremd
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Originally Posted by wyatt View Post
What are the differences, and would they be easy to overcome?
IF I recall correctly the ecu sends a pulse to the injection pump which determines time + duration.
The only issue that I can foresee is that there are actually 2 injection events for every pulse. 1) Pilot event; low flow finer mist. On my car this occours (pop) when the injection pump reaches 224-229 bar and 2)the primary injection event at 307-309 Bar.
I am concerned about the different flow rates per unit time messing up the calculations. AKA at Idle the Pilot injection could be 50% of the injector open time and at WOT it might be 5% of the time.
And at higher RPM the pump is flowing more fuel therefore it will also affect the length of injection events versus time open. (Understand my concern?)
NOTE: 2004 + CARS WILL BE ENTIRELY DIFFERENT THAN MINE. They used Unit injectors.
6 speed ALH TDI
