The signal to quantity adjuster N146 looks promising also, if anyone knows what that signal looks like. It might just be pwm:
"The quantity adjuster is a solenoid, a type of electric motor which adjusts the position
of the modulating piston via an eccentric shaft and thus regulates the fuel quantity
continuously from zero to max. delivery rate."
