Old 02-27-2015, 02:43 PM   #5 (permalink)
EVmetro
Almost forgot, here is the rear suspension all reworked too.
The usual new bearings, seals, shocks, wheel studs upgraded from the stock 10mm to 12mm, and custom inner coils trimmed for my desired spring rate.
New brakes too
Now the batteries get loaded in
This upper beam supports the upper battery box
Here is the upper battery box
Upper rear battery box
Needed a special bus bar to connect these two battery banks
Found some scrap plastic to make the main fuse holder
Here it is installed
The Following 3 Users Say Thank You to EVmetro For This Useful Post:
bespurcell (01-12-2016), mikeyjd (03-19-2015), Xist (02-27-2015)
