Thread: Nissan Leaf
Old 04-01-2015, 12:55 AM   #313 (permalink)
Astro
Dreamer
Originally Posted by rmay635703 View Post
The closest to this I have come is to have the charge timer set so the batteries are fully charged until just before I need to depart, trouble is you really need the car to idle about a half hour before departing without draining the battery to get the battery heated up, this is only really possible on 220v
Ok, here's a crazy idea, probably not suitable for a commercially made vehicle (or any vehicle ).
But how about a low loss capacitive setup where the batteries charge up some capacitors and then the capacitors return the charge to the batteries. Not talking about the whole battery charge just a tiny portion. Like a mini charge and discharge cycle. Repeat the cycle over and over and the batteries would get heated and if losses could be minimised then maybe it would use less power overall compared to having the car on idle for a prolonged time.
In each cycle there would be heat generated in the batteries on both the charge and discharge portion of the cycle.
Maybe even have it integrated into the controller and use the controllers capacitors and ability to feed regen back to the batteries?
