Old 04-01-2015, 07:03 PM   #7 (permalink)
novelinflow
State oftheArt InFlowTech
novelinflow's Avatar
freebeard; that imagen is first chamber side at two different applications;
A-receiving a flow / (like the cool side of a turbo)
B-activate a flow / (like the hot side of a turbo)
And to complete the system, you need to check the other side / Chamber (draw). And at the inclination of the blades at the implocavities
Featured Project Development - State of the Art Novel InFlow Tech: ·1-Gearturbine: Reaction Turbine, ·Rotary-Turbo, Similar System of the Aeolipile ·Heron Steam Device from 10-70 AD, ·With Retrodynamic = DextroGiro/RPM VS LevoGiro/InFlow, + ·Ying Yang Power Type.·2-Imploturbocompressor: Impulse Turbine, ·Implo-Ducted, One Moving Part System Excellence Design, · InFlow Goes from Macro-Flow to Micro-Flow by Implosion/And Inverse, ·One Compression Step.
