i appreciate the replies,
as far as expense i am currently near the atlanta area so i have a few 96+ civics located that would be less expensive with an hx transmission swap figured in. do you have any experience as what could be expected in terms of mpg gain from the hx transmission in an dx/lx/ex? i gathered @ a 4-6mpg increase? they are cars that would need a transmission anyway so i thought i would research the pros and cons of the hx transmission being swapped in, i've also gathered that the hx automatic transmission is very prone to failure os i suppose i will go with the manual, i am not certain about the vx however.
