Old 05-07-2015, 07:13 PM   #5 (permalink)
bentring
Stream - '16 Volkswagen Jetta
90 day: 33.7 mpg (US)
I would expect it could pull a small trailer, although you will probably void your warranty if it is discovered that you do.
I considered a Mirage (but never test drove one) when doing research that led me to my Nissan Note. I knew in the future I would be pulling a trailer at least 50 percent of the time, and I thought having the extra hp and torque available outweighed the slight mpg benefit of the Mirage.
Regarding the trailer situation, the Note doesn't have a tow rating either, but with a manual, I'm not concerned with it hurting the car, and the hitch mounted on the car is for bicycles, obviously.
The Following User Says Thank You to bentring For This Useful Post:
user removed (05-09-2015)
