Old 07-26-2008, 05:16 PM   #22 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Originally Posted by dparker View Post
...We then run the spark plug followed by the pulse plug and measure the difference in fuel consumption...
http://www.pulstarplug.com/pdf/epep.pdf.
Thank you, so there is no A-B-A testing, just the stock plugs first, then the pulse plugs get tested after the engine is more heat soaked?!? If that is the case then the mpg claims are pretty shakey at best.
There was no mention of temperature controls in your testing document.
