Old 05-26-2015, 03:03 PM   #23 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
With the heavy rains here in Texas yesterday, I had to escort someone to the other side of town. This gave me a chance to go do to some dirt flow modeling.
Zipping in through the water, I noticed the water sounded a lot louder than it normally would. Ended up at my destination and made sure my friend made it there safely. As I drove away, I could hear some crunching underneath my truck. Maybe I picked up some debris?
Pulled off into a parking lot do a walk around inspection. Noticed immediately that my rear wheel skirts had popped open since I didn't really secure them to their front fastening point. Oh well...
Looked underneath the truck and found that my main belly pan Coroplast panel was long gone! At least the frame was still there. Guess playing in the water (liquids have up to 200 times more density than gas) ripped it right off the frame and left the screws still attached. The crunching noise was the aluminum flashing dragging on the road. I installed the flashing as a heat shield. I removed what needed to be removed, tucked the flashing back up on top, and had to add more screws to the rear diffuser as some panels had popped off as well to make it home.
So after 5 years, my belly pan will have to be rebuilt. Guess I need to put some more time and thought on how to make it a little better.
Now I'm looking at a metal skin...aluminum would be great as steel will probably fairly heavy. The galvanized metal shed roofing panels would be a good direction as they are pretty cheap and would hold up to road abuse and shouldn't git ripped out should I encounter more deep water.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (05-26-2015), whatmaycome14 (05-27-2015)
