Old 05-29-2015, 10:59 AM   #8 (permalink)
freebeard
The test was a series of 6 runs in ABABAB fashion. A 7th run was done to test a common effect on aerodynamics(will say more at the end).
What is the difference between A and B? The direction of travel? When will we find out about the 'one weird trick' on run #7?
I'm with dirtydave, having different persons driving and timing would eliminate a source of bias.
