Old 06-01-2015, 10:01 AM   #5 (permalink)
Grant-53
I'd say you are on the right track. Sheet material can work instead of fiberglass and a mixing bowl could make a nose piece. Side panels are a bit tricky but I am going to try hinge mine at an angle along the windscreen. The cross section would be pear shaped and larger at the top.
A different handle bar may be needed. Vetter heated and bent his to fit.
The Following User Says Thank You to Grant-53 For This Useful Post:
aerohead (06-01-2015)
