apowers
Thanks for your reply.
I did have it on my bench and testing with two 12 volt batteries. One for supply and one to simulate pack. Have an extra 5K pot and used it for throttle. I can adjust throttle voltage from zero to about 2.2 volts. With a meter across B- and M- I read about point 5 volts. I'll discharge the caps again and check continuity across those two points.
Thanks for the suggestion.
