Old 06-02-2015, 10:17 PM   #12 (permalink)
bennelson
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Yes, I've been reading about how they did Terry's bike over on Craig Vetter's page. That's one reason I wanted to see if I could lower the seat. That was sort of a major change they did on Terry's Zero.
So, today I MAY have started tearing off the back of the motorcycle....
To get the trunk off, I had to remove the plug from the charging cord, pull it through, and then wire it back on again. The wire harness for the tail light and turn signals is all zip-tied to the steel framework of the trunk. A side-cutters made quick work of getting the wire harness off.
Once I got the trunk off, I used the two bolts that held it on to instead hold on a 1x2" board.
With one on either side, I could then add a cross piece and build a ladder-back chair.
If I wanted to do a real, full-blown stream-liner, one concern that I have is swapping out lighting. The headlamp is a standard 12v bulb, but the rest is dedicated 4V LED lighting. I wouldn't easily be able to replace the tail and turn signals with more typical 12V LED lights. (The DC/DC output on the bike is pretty minimal, and it switches 4v power for the brake light and turn signals.)
One thing that I thought might be possible is to keep the stock tail and turn signals, but have them mounted at about my shoulder height.
For right now, I remounted them on a piece of wood, lower. That way, the plastic piece that I don't want to cut off (at least for now) doesn't poke me, and the wire harness easily reaches without modification.
As far as I can tell, this seems street legal for testing around my neighborhood. I screwed the license plate to the back of the upper cross-member.
Sitting in a recumbent position, the backrest is actually really comfortable. The handlebars are a little too far away though.
After monkeying around a bit, I WAS able to figure out how to get all the trim off the handlebars and see what's actually under there. It looks like pretty normal handlebar stuff. I think I should be able to loosen the four middle screws and tilt the handles towards me. I'm not sure if that will be enough or not. If not, replacing it with a different shape/length handlebar shouldn't be too tough.
The wood framing is taller than it needs to be right now. However, it's also a nice point to begin experimentally attaching tail material.
On the Craig Vetter streamliners, he bases the angle of the tail on being a right angle from this "backrest" bulkhead. I'm not sure if that will be too steep or not, but it's something to start from.
Anyone have a bunch of political signs for aero-experimenting?
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
The Following 3 Users Say Thank You to bennelson For This Useful Post:
aerohead (06-03-2015), BamZipPow (06-03-2015), gil (06-03-2015)
