Old 06-05-2015, 03:30 PM   #10 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by Lectrik View Post
LED's are on solid, I can watch with a multi meter as the capacitors go through the pre-charge. That takes less than 3 seconds. The contactor signal never happens so I wired a switch to close the contactor.
No throttle response.
The serial port should be 19,200 baud, no parity, 8 data bits, 1 stop bit. When you power up there should be a message that includes the firmware revision. I didn't see that listed in your messages. Do you get that far?
The Following User Says Thank You to thingstodo For This Useful Post:
Lectrik (06-08-2015)
